Frage Fumes from heating / diesel smell in heating mode
- Wes171
Fumes from heating / Dieselgeruch im Heizbetrieb wurde erstellt von Wes171
Posted 08 Dez. 2022 11:29 #1
Hi
We have a new Columbus 641 and suffer diesel fumes entering the bed area during the night when the heating is on. Anyone got any ideas how to overcome this - is the boiler something that can be adjusted for combustion?
Many Thanks
Many Thanks
von Wes171
- Graeme
- Dank erhalten: 18
Is the window above the outside socket open?
Ist das Fenster über der Außensteckdose geöffnet?
Graeme
Columbus 641E 2021
Columbus 641E 2021
von Graeme
- Wes171
Thanks Graeme
The windows were all shut, with only the bathroom roof vent open, so sadly not an open window fix.
I wondered if it could be venting up through the gas tank enclosure. Shall be experimenting and investigating when we are not camping, as it’s too much of a faff raising the bed foot just now.
von Wes171
- p0ddie
- Dank erhalten: 41
I'm late to the party, merry christmas. Check if the exhaust is connected properly, it's not normal to smell exhaust fumes except for aforementioned case: the window just above the exhaust is open.
I suspect there's an exhaust leak, not good. Get this checked out and also while you're at it you might want to invest into a co warning device.
von p0ddie
Folgende Benutzer bedankten sich: Wes171
willi-heinrich antwortete auf Fumes from heating / Dieselgeruch im Heizbetrieb
Posted 26 Dez. 2022 15:21 #5
The exhaust is outside the bus, so any leak will not make a differente inside.
The entrance of the 2 water pipes might not ne sealed properly.
Other than that it is probably exhaust fumes that enter through normal vent openings - the Bus is not airtight. The gas vent may be one of them, but the gas box should be gastight towards the inside of the bus.
- Wes171
Wes171 antwortete auf Fumes from heating / diesel smell in heating mode
Posted 17 Jan. 2023 19:24 #6
Hi All
Thanks for the comments. Took the van back to dealer who realigned the heater exhaust to poke out further from the side of the vehicle and having been away this weekend, good news, no fumes in the bed area although it wasn't as cold (freezing) as when we first experienced this problem. Fingers crossed, as having a Duvalay topper on the bed makes it so comfortable that we now both enjoy a really good nights sleep in the van.
We have a combined CO2 and fire alarm mounted on the WC side wall - we are now getting used to the pulsing flashes from the
Happy Camping
Happy Camping
von Wes171
