Frage Columbus 600D Fridge drawer type running non stop and freezing at lowest setting
  • jFrey04
  • jFrey04s Avatar Offline Autor
Columbus 600D Fridge drawer type running non stop and freezing at lowest setting wurde erstellt von jFrey04
Posted 10 Juni 2021 14:54 #1
Hello! everyone,
I have a Columbus 600 D from 2013 bought recently.
The fridge at it's lowest position runs continuously up to freezing !... I suppose the thermostat sensor is failing.
I have read in the forum  i am not the only one facing this failure.
There is an how-to to replace the Thermostat sensor ?
Some help will greatly appreciated
Best regards to the Westfalia Fan community
Jfrey04
von jFrey04
  • ychsel
  • ychsels Avatar Offline
  • Dank erhalten: 122
Hi Jfrey04,
I did not replace it but suppose it is easy, if you can get the spare part. When I built in a more silent fan for the fridge i discovered the sensor cable coming from the fridge to the controller. I have a 540D, so I am not sure if your 600 has the fridge at the same position. My fridge is below the stove. Under the stove there are two black plastic cover for the heat release of the compressor. If you take the inner cover you see the fridge controller and the little cable coming from the back of the fridge. It is sealed at fridge wall with some elastic material.
Some more details you can find in this very good blog  here .
Good luck!
Axel
von ychsel
  • jFrey04
A big thank you! Axel for you reply.
I have checked the Blog but unfortunately the Columbus has not the same fridge arrangement.
I have open the drawer and lift it up like explain in an other topic, but from there?
There is an aluminium cage protecting the cool box and i don't now how to proceed next !?
Regards
jFrey 04
von jFrey04
