Frage Descaling heater
  • Stuworx
  • Stuworxs Avatar Offline Autor
Descaling heater wurde erstellt von Stuworx
Posted 03 Aug. 2024 17:24 #1
does anyone know if or has descaled the heating system?
I regularly do our kettle at home and the van and assume the heater could also build up timescale?
thanks in advance.
Stuart.
von Stuworx
  • sebhro
  • sebhros Avatar Offline
sebhro antwortete auf Descaling heater
Posted 05 Aug. 2024 08:26 #2
Hi, I don't think we need to do a descaling because the heating system uses a special fluid. Maybe only the boiler needs to be descaled.
Best regards
Grüße aus Rostock
von sebhro
willi-heinrich antwortete auf Descaling heater
Posted 05 Aug. 2024 09:30 #3
The boiler does not get hotter than about 60C, therefore scaling should be minimal. Have you ever descaled your water heater at home?
A kettle that boils is a different thing, at higher temperatures scaling increases a lot.
Folgende Benutzer bedankten sich: Stuworx
