Frage Leaking heating?
  • quentinsf
  • quentinsfs Avatar Offline Autor
  • Dank erhalten: 5
Leaking heating? wurde erstellt von quentinsf
Posted 12 Jan. 2025 11:18 #1
(Sorry for posting in English)
The heating on our new 540D seems to have a leak.   I will take it back to the dealer, because I don't feel like going out at this time of year without heat!
But has anybody seen this before?  The van is three days old, so I wouldn't know where to start looking!
Thanks!
Quentin
Anti-freeze puddle by the sliding door:
[img][/img]
When I wipe it up, it appears again, and after a few days, the filler tank is empty.
[img][/img]
Last Edit:12 Jan. 2025 12:11 von quentinsf
Letzte Änderung: 12 Jan. 2025 12:11 von quentinsf. Begründung: Trying pictures again
  • quentinsf
  • Dank erhalten: 5
quentinsf antwortete auf Leaking heating?
Posted 12 Jan. 2025 11:22 #2
Sorry - I don't have permissions to post pictures!
von quentinsf
willi-heinrich antwortete auf Leaking heating?
Posted 13 Jan. 2025 12:35 #3
We had a leak too when we got ours. Pipe not fixed properly. Fortunately it dripped out under the car, not inside. The dealer had to fix it.
it takes 5 posts to be able to post pictures (anti spam)
  • quentinsf
  • Dank erhalten: 5
Posted 13 Jan. 2025 18:24 #4
As part of the winter pack, there is an extra heat outlet under the passenger seat, and I think the leak is coming from the pipes that go to that. There are clips connecting those pipes in the under-floor cupboard, and I think those clips may just need to be tighter. (I don't know if their position is different if you have the driver's seat on the left!)
This is good, because it's very easy to do - almost the only place where the pipes can actually be seen! But it's going back to the dealer for testing anyway.
It would be easy to bump those clips if you were sliding something heavy into that little
von quentinsf
