Frage 12v or 24v system?
  • Stuworx
  • Stuworxs Avatar Offline Autor
12v or 24v system? wurde erstellt von Stuworx
Posted 21 Juli 2026 10:08 #1
Hello,
We have a Columbus 601d.
i recently changed the leisure batteries like for like. The original westfalia control panel reads the usual voltage 12.8, 13 etc but the Victron solar charger is set to 24v and shows a half full battery?
is the system definitely 12v not 24v? Should I change the victron solar controller?
if it’s 12v but solar thinks it’s 24v surely it will overcharge and cause damage!
thank you.
von Stuworx
willi-heinrich antwortete auf 12v or 24v system?
Posted 21 Juli 2026 12:59 #2
correct. The solar charger setting us wrong. Should be set to 12 V
