Gelöst Solarladeregler Amundsen 2021/2022
- Dante
Thanks for the response Sop. I will cover the solar panel and try to change it. greetings
von Dante
- Dank erhalten: 385
Best of luck 👍👍👍
- Dante
Hello Sop, I already changed the regular Solara for the Victron. Everything went well, thanks for your advice. Now I was setting up the victron app. Can you tell me what parameters have been modified so that functions work correctly? I have everything as standard, I haven't changed batteries or anything. thank you
von Dante
Hello Dante,
great everything worked 👍
All I changed in the app were the battery settings. I changed it to "smart battery (LiFePo4)" because I have a lithium battery. That was all I changed.
If you choose your battery type everything should automaticaly be set to the wright parameters.
Greetings Sop
Greetings Sop
- Dante
I have 2 batteries under the seat and I don't know if I have to do any special configuration.
I have tried to talk to westfalia but I have not answer….i will keep trying
von Dante
I would think that you have AGM batteries (2x 95Ah), as you didn't change anything (but look what is written on the batteries).
I found this video about how to change the battery settings to the right battery type:
And hier somebody saks about the battery settings with an AGM batteries:
www.photovoltaikforum.com/thread/138733-...15-mit-agm-batterie/
Unfortunally in german, but maybe it will help anyway...
Good luck!
Greetings Sop
Good luck!
Greetings Sop
