Frage So entfernen Sie den Kühlschrank
  • Graeme
  • Graemes Avatar Offline Autor
  • Dank erhalten: 18
So entfernen Sie den Kühlschrank wurde erstellt von Graeme
Posted 18 Juni 2025 10:38 #1
I suspect the thermostat is defective, but I can't even remove the fridge!
We have a low refrigerator in a 641E. Vitrifrigo C95
The refrigerator seems to be fixed with four screws: two from the cabinet that holds the drawers under the sink and two from the small cabinet on the other side.
I removed these, but the fridge is still stuck.
The screw holes in the refrigerator do not appear to have been used during installation.
There is a mounting frame, but I don't see a way to remove it until the fridge is removed.
Graeme
Columbus 641E 2021
Last Edit:18 Juni 2025 10:39 von Graeme
Letzte Änderung: 18 Juni 2025 10:39 von Graeme. Begründung: more info
  • Graeme
  • Dank erhalten: 18
Graeme antwortete auf So entfernen Sie den Kühlschrank
Posted 23 Juni 2025 09:29 #2
hat keiner eins rausgenommen????
Graeme
Columbus 641E 2021
von Graeme
  • Stuworx
  • Stuworxs Avatar Offline
Stuworx antwortete auf So entfernen Sie den Kühlschrank
Posted 11 Mai 2026 20:45 #3
Hello Graeme,
did you have any luck removing the fridge?
I think I need to remove ours.
Stuart.
von Stuworx
willi-heinrich antwortete auf So entfernen Sie den Kühlschrank
Posted 12 Mai 2026 09:27 #4
  • Graeme
  • Dank erhalten: 18
Posted 13 Mai 2026 11:13 #5
Yes we did, and had it repaired. All is good now.
The link above gives a great description, except in the 641 you can't remove the shower door as it doesn't open wide enough. ( you could remove it by unscrewing the hinges, but you don't need to)
Graeme
Columbus 641E 2021
von Graeme
